[petsc-dev] Just a quick question
Paul Mullowney
paulm at txcorp.com
Tue Jan 8 10:52:53 CST 2013
Hi Keita,
There is a CUSPARSE class in PETSc that is under active development. I
can show you how to use if you are interested.
-Paul
> Hello PETSc Developers,
> I have a quick question about NVIDIA GPU support of PETSc. As far as
> I know, the current version uses thrust and cusp-0.31. However, cusp
> project has been not so active for a while. I am just curious if
> PETSc will continue using cusp, or do you have any plan to replace
> CUSPARSE?
> Regards,
> Keita Teranishi
> Scientific Library Group
> Cray Inc.
> keita at cray.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130108/63d6dcb0/attachment.html>
