[petsc-dev] Counting Fortran function pointers
Jed Brown
jedbrown at mcs.anl.gov
Mon Jan 7 17:48:13 CST 2013
Richard, it's better to mail the list. No, we haven't reworked subtype
Fortran pointers yet, but I think we know what needs to be done.
On Mon, Jan 7, 2013 at 1:42 PM, Richard Tran Mills <rtm at eecs.utk.edu> wrote:
> Hi Jed,
> I am back at work after some extended time away and I need to start
> messing with DMShell so that I can use it to set operations like
> LocalToGlobal and GlobalToLocal updates from inside PFLOTRAN.
> Did this issue of handling the Fortran function pointers get resolved
> somehow? Is there something I need to change in how I am doing the Fortran
> bindings?
> Cheers,
> Richard
> On 12/4/12 5:43 PM, Jed Brown wrote:
> As usual, anything that is duplicated and not checked by the compiler is
> broken.
> $ grep PetscObjectAllocateFortranPointers src/**/*.c
> src/dm/impls/da/ftn-custom/zda2f.c:
> PetscObjectAllocateFortranPointers(*da,6);
> src/dm/impls/shell/ftn-custom/zdmshellf.c:
> PetscObjectAllocateFortranPointers(*dm,2);
> Note that changing the type does not reset the function pointers, thus
> having a DMSHELL, calling DMSetType(dm,DMDA), and then setting a DMDA local
> function will cause memory corruption.
> I cannot express how much I hate this system. The full-blown solution is
> that for each type, we register a (global) token which is the index of that
> function pointer. That doesn't have any false dependencies, but is more
> "initialize" code.
> An alternative, used in the TS and KSP code below, is to have a common
> enum that lists all the Fortran functions. It's a false header dependency,
> but not a binary dependency.
> What should we do? The current state is a disaster.
> src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c:
> PetscObjectAllocateFortranPointers(*ksp,3);
> src/ksp/ksp/interface/ftn-custom/zitfuncf.c:
> PetscObjectAllocateFortranPointers(*ksp,FTN_MAX);
> src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.c:
> PetscObjectAllocateFortranPointers(*mat,1);
> src/ksp/pc/impls/shell/ftn-custom/zshellpcf.c:
> PetscObjectAllocateFortranPointers(*pc,5);
> src/mat/impls/mffd/ftn-custom/zmffdf.c:
> PetscObjectAllocateFortranPointers(*mat,2);
> src/mat/impls/shell/ftn-custom/zshellf.c:
> PetscObjectAllocateFortranPointers(*mat,11);
> src/mat/interface/ftn-custom/zmatrixf.c:
> PetscObjectAllocateFortranPointers(*sp,1);
> src/snes/interface/ftn-custom/zsnesf.c:
> PetscObjectAllocateFortranPointers(*snes,14);
> src/snes/linesearch/impls/shell/ftn-custom/zlinesearchshellf.c:
> PetscObjectAllocateFortranPointers(*linesearch,3);
> src/snes/linesearch/interface/ftn-custom/zlinesearchf.c:
> src/sys/draw/utils/ftn-custom/zzoomf.c:
> PetscObjectAllocateFortranPointers(*draw,1);
> src/ts/interface/ftn-custom/ztsf.c:
> PetscObjectAllocateFortranPointers(*ts,OUR_COUNT);
> Richard Tran Mills, Ph.D.
> Computational Earth Scientist | Joint Assistant Professor
> Hydrogeochemical Dynamics Team | EECS and Earth & Planetary Sciences
> Oak Ridge National Laboratory | University of Tennessee, Knoxville
> E-mail: rmills at ornl.gov V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130107/3f405794/attachment.html>
