[petsc-dev] Nonblocking consensus and alternative "freespace" interface
Jed Brown
jedbrown at mcs.anl.gov
Mon Jan 7 17:28:41 CST 2013
On Mon, Jan 7, 2013 at 3:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> The PetscOptions and PetscInfo functions are examples where we used
> _Private to
> indicate a lower level interface, rather than one that was truly file
> scope. I guess we
> need two different specifiers.
Most of these are in matimpl.h and vecimpl.h. They should perhaps be called
_Internal since they are shared inside PETSc, but not public. We should
also change them from PETSC_EXTERN so that we can set visibility=hidden to
prevent users from calling them through shared libraries. ;-)
I don't have a problem with non-namespaced functions at file local scope,
they just have to be renamed if they are ever referenced from elsewhere.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130107/cec40fd5/attachment.html>
