[petsc-dev] UMFPACK + Intel compiler
Jed Brown
jedbrown at mcs.anl.gov
Sat Jan 5 10:45:14 CST 2013
On Sat, Jan 5, 2013 at 10:41 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> I've hit a problem with letting PETSc download and build UMFPACK when
> using Intel compilers. Unfortunately I don't know a fix. The problem
> is the compiler directive:
> -DUF_long="long long"
> that PETSc writes to
> externalpackages/UMFPACK-5.5.1/UFconfig/UFconfig.mk. The Intel
> compiler (version 12..1.4) doesn't seem to like the white space
> between the two 'longs'. I get:
> mpicc -fPIC -wd1572 -mt_mpi -O3 -xHost -DUF_long="long long"
> -DUF_long_max=ULONG_MAX -DUF_long_id='"%lld"' -DNCHOLMOD -I../Include
> -I../../UFconfig -DDINT -c ../Source/amd_aat.c -o amd_i_aat.o
> icc: error #10236: File not found: 'long'
This error message sure makes it look like a shell quoting problem. Can you
interrogate the compiler on the side to see if it's really breaking
arguments at spaces internally (after they are passed by the shell)? If
that's the case, we might have to write the definitions into a header.
> I'm using petsc-dev (changeset: 25580:4a0800bf1994)
> Garth
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130105/49af5076/attachment.html>
