[petsc-dev] Problem Assembling MatCreateAIJ (Parallel Sparse Matrix)
Matthew Knepley
petsc-maint at mcs.anl.gov
Thu Jan 3 14:53:41 CST 2013
I don't think I understand what you are doing. Can you send a small example?
Matt
On Jan 3, 2013 2:51 PM, "Hesameddin Ilatikhameneh" <hilatikh at purdue.edu>
wrote:
> I noticed that the problem occurs when I try to set some of non-local
> (non-diagonal) matrix elements. i.e. in a 3x3 matrix with 2 cpus, if I try
> to set non-local diagonal elements it is OK but if I try to set some
> non-diagonal elements [0][2] or [2][0] it gives the error. It is wired that
> setting [0][1] or [1][0] is OK too.
> I tried CHKERRXX too and got the similar error message (attached below).
> [0]PETSC ERROR: [1]PETSC ERROR: VecScatterCreateCommon_PtoS() line 2003 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/vec/vec/utils/vpscat.c
> [0]PETSC ERROR: VecScatterCreate_PtoS() line 1807 in
> [0]PETSC ERROR: VecScatterCreate() line 1331 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/vec/vec/utils/vscat.c
> [0]PETSC ERROR: MatSetUpMultiply_MPIAIJ() line 150 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/mat/impls/aij/mpi/mmaij.c
> [0]PETSC ERROR: MatAssemblyEnd_MPIAIJ() line 702 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatAssemblyEnd() line 4879 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/mat/interface/matrix.c
> VecScatterCreateCommon_PtoS() line 2013 in
> [1]PETSC ERROR: VecScatterCreate_PtoS() line 1807 in
> [1]PETSC ERROR: VecScatterCreate() line 1331 in
> [1]PETSC ERROR: MatSetUpMultiply_MPIAIJ() line 150 in
> [1]PETSC ERROR: MatAssemblyEnd_MPIAIJ() line 702 in
> [1]PETSC ERROR: MatAssemblyEnd() line 4879 in
> Thanks
> Hesam
> From: "Matthew Knepley" <petsc-maint at mcs.anl.gov>
> To: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov
> Sent: Thursday, January 3, 2013 3:12:28 PM
> Subject: Re: [petsc-dev] Problem Assembling MatCreateAIJ (Parallel Sparse
> Matrix)
> We cannot see the error message. Use CHKERRXX
> Matt
> On Jan 3, 2013 1:11 PM, "Hesameddin Ilatikhameneh" < hilatikh at purdue.edu> wrote:
> The point is the problem occurs when I'm assembling the matrix and since
> it is unsuccessful MatView gives error.
> I assemble the matrix:
> this->Petsc_Error =
> MatAssemblyBegin(*(this->Petsc_Mat),MAT_FINAL_ASSEMBLY);
> this->Check_Petsc_Error();
> this->Petsc_Error = MatAssemblyEnd(*(this->Petsc_Mat),MAT_FINAL_ASSEMBLY);
> Thanks
> Hesam
> From: "Jed Brown" < jedbrown at mcs.anl.gov >
> petsc-dev at mcs.anl.gov >
> Cc: "petsc-maint" < petsc-maint at mcs.anl.gov >
> Sent: Thursday, January 3, 2013 2:07:40 PM
> Matrix)
> You have to assemble the matrix, just like the error message says.
> On Jan 3, 2013 1:00 PM, "Hesameddin Ilatikhameneh" < hilatikh at purdue.edu> wrote:
> Hello,
> When I try to assemble a parallel sparse matrix (MatCreateAIJ) I get the
> following error. But when I try to set the parallel matrix in dense format
> I don't get any error. I used PETSC_DECIDE for number of local elements and
> number of local nonzeros and PETSC_NULL for nonzeros array in MatCreateAIJ.
> [0]PETSC ERROR: [1]PETSC ERROR: VecScatterCreateCommon_PtoS() line 2013 in
> [0]PETSC ERROR: User provided function() line 65 in
> "unknowndirectory/"/home/Codes/trunk/HSim2/Include/Math/PetscMatrix.h
> [1]PETSC ERROR: User provided function() line 65 in
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Operation done in wrong order!
> [0]PETSC ERROR: Must call MatAssemblyBegin/End() before viewing matrix!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 5, Sat Dec 1 15:10:41
> CST 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./bin_Ubuntu/HSim2 on a linux-gnu named hesam2-VirtualBox
> by hesam2 Thu Jan 3 13:44:28 2013
> [0]PETSC ERROR: Libraries linked from
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/linux-gnu-real/lib
> [0]PETSC ERROR: Configure run at Fri Dec 21 08:15:55 2012
> [0]PETSC ERROR: Configure options
> PETSC_DIR=/home/Codes/trunk/Libs/Petsc/PETSC_Build_Real
> PETSC_ARCH=linux-gnu-real --with-shared-libraries
> --download-f-blas-lapack=1 --with-single-library=0 --with-shared-libraries
> --with-debugging=1 --with-scalar-type=real
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatView() line 740 in
> Many Thanks
> Hesam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130103/ecbe5d1d/attachment.html>
