[petsc-dev] Problem Assembling MatCreateAIJ (Parallel Sparse Matrix)
Thu Jan 3 13:07:40 CST 2013
You have to assemble the matrix, just like the error message says.
On Jan 3, 2013 1:00 PM, "Hesameddin Ilatikhameneh" <hilatikh at purdue.edu>
wrote:
> Hello,
> When I try to assemble a parallel sparse matrix (MatCreateAIJ) I get the
> following error. But when I try to set the parallel matrix in dense format
> I don't get any error. I used PETSC_DECIDE for number of local elements and
> number of local nonzeros and PETSC_NULL for nonzeros array in MatCreateAIJ.
> [0]PETSC ERROR: [1]PETSC ERROR: VecScatterCreateCommon_PtoS() line 2013 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/vec/vec/utils/vpscat.c
> [0]PETSC ERROR: VecScatterCreate_PtoS() line 1807 in
> [0]PETSC ERROR: VecScatterCreate() line 1331 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/vec/vec/utils/vscat.c
> [0]PETSC ERROR: MatSetUpMultiply_MPIAIJ() line 150 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/mat/impls/aij/mpi/mmaij.c
> [0]PETSC ERROR: MatAssemblyEnd_MPIAIJ() line 702 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatAssemblyEnd() line 4879 in
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/src/mat/interface/matrix.c
> [0]PETSC ERROR: User provided function() line 65 in
> "unknowndirectory/"/home/Codes/trunk/HSim2/Include/Math/PetscMatrix.h
> VecScatterCreateCommon_PtoS() line 2003 in
> [1]PETSC ERROR: VecScatterCreate_PtoS() line 1807 in
> [1]PETSC ERROR: VecScatterCreate() line 1331 in
> [1]PETSC ERROR: MatSetUpMultiply_MPIAIJ() line 150 in
> [1]PETSC ERROR: MatAssemblyEnd_MPIAIJ() line 702 in
> [1]PETSC ERROR: MatAssemblyEnd() line 4879 in
> [1]PETSC ERROR: User provided function() line 65 in
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Operation done in wrong order!
> [0]PETSC ERROR: Must call MatAssemblyBegin/End() before viewing matrix!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 5, Sat Dec  1 15:10:41
> CST 2012
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./bin_Ubuntu/HSim2 on a linux-gnu named hesam2-VirtualBox
> by hesam2 Thu Jan  3 13:44:28 2013
> [0]PETSC ERROR: Libraries linked from
> /home/Codes/trunk/Libs/Petsc/PETSC_Build_Real/linux-gnu-real/lib
> [0]PETSC ERROR: Configure run at Fri Dec 21 08:15:55 2012
> [0]PETSC ERROR: Configure options
> PETSC_DIR=/home/Codes/trunk/Libs/Petsc/PETSC_Build_Real
> PETSC_ARCH=linux-gnu-real --with-shared-libraries
> --download-f-blas-lapack=1 --with-single-library=0 --with-shared-libraries
> --with-debugging=1 --with-scalar-type=real
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatView() line 740 in
> Many Thanks
> Hesam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130103/168873da/attachment.html>
