[petsc-dev] MPI type mismatches
Jed Brown
jedbrown at mcs.anl.gov
Wed Jan 2 15:13:38 CST 2013
If you have Clang and MPICH-3.0, all MPI types should now be checked
(including the types that PETSc creates).
https://bitbucket.org/petsc/petsc-dev/commits/a7385c2b2cce59d13c376cee7ce8117a20c668ac
On Sun, Dec 30, 2012 at 11:33 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> I've pushed fixes for the PetscBool and PetscEnum instances. Please use
> MPIU_BOOL and MPIU_ENUM in new code. The Complex cases still produce
> warnings. Let me know if you object to my ripping out those special cases.
> https://bitbucket.org/petsc/petsc-dev/commits/659ebb827654e17cd01d6fb5cf1a54155f4e77a7
> On Sun, Dec 30, 2012 at 10:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> I just fixed a bunch of dangerous type mismatches. Presumably a number of
>> things were broken with 64-bit integers, at least in cases with overflow.
>> https://bitbucket.org/petsc/petsc-dev/commits/146d1df88e306d69e6ce797932b1c3352fd7851c
>> These were warnings with clang-3.2. A year ago when people were working
>> on this feature, I downplayed its importance, claiming that it's just not a
>> mistake that I tend to make. Based on the sheer number of these mistakes in
>> PETSc, I now believe it's a fantastic feature.
>> There are still a lot of warnings, though I believe the remaining ones
>> are benign. (The most common is sending PetscBool as MPI_INT.) Since people
>> will use clang-3.2 and we want to see the real mistakes, we have to silence
>> these benign warnings. I'm working through annotation of these.
>> Another problem case is using a Real reduction of twice the size to sum
>> Complex, e.g., in vscat.c. I suspect this code predates definition of
>> MPIU_SUM working with complex, and can thus be removed. Is that the case,
>> or is there some reason we need to keep both around?
>> #if defined(PETSC_USE_COMPLEX)
>> ierr =
>> MPI_Reduce(xv,xvt,2*xx_n,MPIU_REAL,MPIU_SUM,0,((PetscObject)ctx)->comm);CHKERRQ(ierr);
>> #else
>> ierr =
>> MPI_Reduce(xv,xvt,xx_n,MPIU_SCALAR,MPI_SUM,0,((PetscObject)ctx)->comm);CHKERRQ(ierr);
>> #endif
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130102/b9b17763/attachment.html>
