[petsc-dev] A closer look at the Xeon Phi
Jed Brown
jedbrown at mcs.anl.gov
Tue Feb 12 19:14:59 CST 2013
On Tue, Feb 12, 2013 at 7:09 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Which crossover are you referring to? The CPU versus GTX285 at about 20k
>> dofs, but with only very small gains for another order of magnitude?
> I assume it's the cross-over of Xeon Phi vs. Xeon,
MIC is slower than Xeon by more than an order of magnitude at 10k dofs.
> but almost all cross-overs happen in the 10k-100k region and are due to
> PCI-Express latency.
Why is PCI-Express latency important here? Can't the MIC code run entirely
on the device?
> Scaling this to large clusters, replace Xeon Phi by compute node,
> PCI-Express by GB-Ethernet/Infiniband as well as change the timescale a bit
> and you're probably not too far off...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130212/3e8570a6/attachment.html>
