[petsc-dev] IMP prototype
Tue Dec 31 02:37:10 CST 2013
Victor Eijkhout <eijkhout at tacc.utexas.edu> writes:
> Since multiple iterations of NSF reviewers & conference referees have
> failed to understand my theory (the fact that I'm still converging on
> the best explanation may have something to do with it) I've decided to
> put on my coding hat and show that IMP can actually work.
How would you propose to handle irregular communication patterns such as
you would get with a small number of dense rows in a sparse matrix, or
the row/column communicators for dense linear algebra?  How are
reductions expressed and implemented?
I think that the setup costs are actually critical.  They are not always
amortized in either dynamic execution models or methods with frequent
adaptivity, particle transport, self-contact, etc.  The MPI model may
already have two-sided knowledge about the new communication pattern or
know a good way to use collectives.  It's more work for the programmer
to specify both sides of the communication, but dynamic exchange is
significantly more expensive.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131231/585fd0a7/attachment.sig>
