[petsc-dev] change to VecView_MPI_ASCII() major affect on nightly builds
Barry Smith
bsmith at mcs.anl.gov
Tue Dec 24 10:55:09 CST 2013
Jed,
Your call to PetscObjectGetName() is causing major changes to example output
77ae766c src/vec/vec/impls/mpi/pdvec.c (Jed Brown 2013-12-21 18:23:45 -0700 54) ierr = PetscObjectGetName((PetscObject)xin,&name);CHKERRQ(ierr);
77ae766c src/vec/vec/impls/mpi/pdvec.c (Jed Brown 2013-12-21 18:23:45 -0700 55) ierr = PetscViewerGetFormat(viewer,&format);CHKERRQ(ierr);
because now all Vecs have names when printed so nightly tests are filled with
1c1
< Vec Object: 2 MPI processes
> Vec Object:Vec_0x84000005_0 2 MPI processes
/home/balay/petsc.clone-3/src/vec/vec/examples/tests
Possible problem with with ex3_1, diffs above
1c1
> Vec Object:Vec_0x84000004_0 2 MPI processes
Possible problem with with ex9_1, diffs above
How do we want to deal with this? Normally in the past Vec’s never had names. Could you put the PetscObjectGetName() back in a place where it only gets called when truly needed like when viewer with Matlab instead of all the time? Note that it still only gets called when needed in VecView_Seq_ASCII.
Thanks
Barry
Request-assigned: Jed VecView_MPI_ASII() always prints Vector name now resulting in messy nightlys
