[petsc-dev] http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/12/2 0/examples_master_arch-linux-c89_thrash.log
Barry Smith
bsmith at mcs.anl.gov
Sat Dec 21 23:07:56 CST 2013
On Dec 21, 2013, at 10:47 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> So a known problem that has been hanging around for a long time breaking our tests but never fixed.
> Yes, unfortunately. The right answer depends on what we want -std=c89
> to do. If we intend to use feature test macros to enable POSIX, the
> test snippet should do so and then we'll use
This sounds reasonable. So PETSC_DESIRE_FEATURE_TEST_MACROS just needs to be added in the PetscRand_Rand48() file and the python missing test augmented? Then make it so.
> If we are trying to produce an
> artificially-limited environment that can only be found on very obscure
> and obsolete operating systems, then maybe we should have a
> --with-feature-test-macros=0 option.
The intention is that -std=c89 is used to insure that young bucking broncos don’t use every subtle feature of c99 all over the source code. It is not intended to cripple us.
Barry
>> Hmm, then maybe it should be removed rom the list
>> functions = ['access', '_access', 'clock', 'drand48', 'getcwd', '_getcwd', 'getdomainname', 'gethostname’,
>> it is confusing to have it tested in two places, I saw this one and just assumed it is the only place.
> Indeed.
>> request-assigned: petsc-dev missing drand48() prototype with -std=c89
> Is this a tagging experiment of yours?
