[petsc-dev] PETSC_UNUSED syntax?
Jed Brown
jedbrown at mcs.anl.gov
Sat Dec 21 19:49:57 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> It seems some compilers don’t like applying attributes to only some variables being declared. Is this legitimate? Should we always be marking the unused variables on lines of their own? (I have no problem doing that).
> /sandbox/petsc/petsc.clone-2/arch-linux-complex-gcov/bin/mpicxx -o ex10.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fprofile-arcs -ftest-coverage -g -O0 -fPIC -I/sandbox/petsc/petsc.clone-2/include -I/sandbox/petsc/petsc.clone-2/arch-linux-complex-gcov/include `pwd`/ex10.c
> /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex10.c: In function ‘PetscErrorCode RDIJacobian_FE(TS, PetscReal, Vec, Vec, PetscReal, _p_Mat**, _p_Mat**, MatStructure*, void*)’:
> /sandbox/petsc/petsc.clone-2/src/ts/examples/tutorials/ex10.c:710:36: warning: ignoring attributes applied to ‘std::complex<double>’ after definition [-Wattributes]
> PetscScalar D_R,PETSC_UNUSED rad;
> request-assigned: petsc-dev PetscScalar D_R,PETSC_UNUSED rad; warning: ignoring attributes applied to ‘std::complex<double>’ after definition
Okay, but what compiler is being this unhelpful?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131221/b86e7fe7/attachment.sig>
