[petsc-dev] CheckPointer
Jim Fonseca jefonseca at gmail.com
Thu Dec 19 16:59:19 CST 2013
Great, thank you Matt and Jed
On Thu, Dec 19, 2013 at 2:08 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Sep 30, 2013 at 12:25 PM, Jim Fonseca <jefonseca at gmail.com> wrote:
>> Hi,
>> Does anyone have an update on PetscCheckPointer?
> Jed pushed a fix for this.
>    Matt
>> Thanks,
>> Jim
>> On Wed, Sep 11, 2013 at 12:14 PM, Dave May <dave.mayhem23 at gmail.com>wrote:
>>> I would be much happier with run-time as well, but I could also live
>>> with a reconfigure (it's just one MORE petsc build on my machine :D).
>>> What ever can be done to fix this issue would be appreciated.
>>> Cheers,
>>>   Dave
>>> On 11 September 2013 18:12, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> Dave May <dave.mayhem23 at gmail.com> writes:
>>>> > Yes, being able to optionally turn off the full memory checking
>>>> (either run
>>>> > time or via a configuration flag) in MatSetValues() would be good
>>>> enough.
>>>> I'd rather make everything run-time unless it absolutely must be
>>>> configure time because it sucks to reconfigure (and possibly rebuild
>>>> downstream libraries/packages).
>>>> > Presumably when the full error checking wasn't being used, the error
>>>> > checking should revert to using the old style memory checking (e.g.
>>>> ptr != 0)
>>>> > as was used in version 3.2 (and maybe 3.3, I cannot recall).
>>>> Yes.  As far as I'm concerned, it should also try to dereference it so
>>>> that a SEGV occurs early rather than later.  The only difference between
>>>> safe and fast mode is that the SEGV in safe mode is caught by a friendly
>>>> signal handler than cleans up and returns so that a normal error can be
>>>> propagated.
>> Jim Fonseca, PhD
>> Research Scientist
>> Network for Computational Nanotechnology
>> Purdue University
>> 765-496-6495
>> www.jimfonseca.com
> experiments lead.
> -- Norbert Wiener
Jim Fonseca, PhD
Research Scientist
Purdue University
765-496-6495
www.jimfonseca.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131219/e2abc9c9/attachment.html>
