[petsc-dev] BG hang still broken in petsc-maint!
Jed Brown
jedbrown at mcs.anl.gov
Wed Dec 18 15:44:54 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> ~/.petscrc does not get loaded for me on vesta [with maint] - as there
> is no $HOME in the run env.
We still attempt it for the current directory (./.petscrc and ./petscrc).
I dug into the PAMID source, but the environment variable processing is
not something we can mess with later without some support being added
inside MPICH/PAMID. If PETSc calls MPI_Init(), we could use setenv()
before, though that could be surprising.
We could write our own reference MPI_Bcast over point-to-point. Our
messages are always pretty short so this is actually a decent algorithm
and would be best for the users (most reliable, least confusing).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131218/e38c6afb/attachment.sig>
