[petsc-dev] BG hang still broken in petsc-maint!
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Dec 18 14:14:27 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> I had a chat with Derek today morning. The error case was with 512
> nodes [same as above] with --ranks-per-node 4 or 8. And this was on
> ceatus.
It is spelled "cetus".
> The hang was confirmed to be in PetscInitialze [via the debugger] and
> -skip_petscrc went past the hang.
That is where the particular sequence of collectives (MPI_Bcast) gets
called.  Getting past that part does not rule out the same problem
occurring later, perhaps with lower probability.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131218/283d7ca2/attachment.sig>
