[petsc-dev] BG hang still broken in petsc-maint!
Jed Brown
jedbrown at mcs.anl.gov
Wed Dec 18 13:34:49 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Works for me on vesta with [the following on sys/examples/tutorials/ex1]
> runjob --np 8192 --ranks-per-node 16 --cwd $PWD --block VST-00440-33771-512 : $PWD/ex1 -log_summary
This is only 512 nodes. According to ALCF, the probability of MPI_Bcast
crossing paths goes way up at more than 1024 nodes. IBM should really
fix this problem, but until then, the workaround is to fall back to the
reference implementations (PAMID_COLLECTIVES=0) which are sometimes
also faster (go figure).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131218/74bb69a7/attachment.sig>
