[petsc-dev] unable to merge into next from a branch from master
Matthew Knepley
knepley at gmail.com
Tue Dec 17 08:41:09 CST 2013
On Tue, Dec 17, 2013 at 8:28 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Dec 17, 2013 at 8:25 AM, Peter Brune <prbrune at gmail.com> wrote:
>> OK, it's completely ludicrous that this isn't fixed. Matt, you have this
>> series of changesets
> I am fucking traveling. I will fix it when I come home tonight.
Fixed.
Matt
> As the changeset comments read, I was fixing a bad rebase. The changesets
> were dropped from
> a branch, but had been in master for a long time. I was just merging them
> to master as we do
> for all branches we want in.
> I do not understand why the merge to master had problem with next, but it
> will be simple to fix
> when I am on the bus tonight.
> Matt
>> 69d8a9c DMPlex: More fixup from bad rebase, moved to
>> DMGet/SetCoordinateSection()
>> e8abe2d DM: Added DMGet/SetCoordinateSection()
>> d7a12f9 Fuckup: Fix for merge that is still untangling bad rebase from
>> Oct. 17th 2013 - Fixed const in declarations - Fixed merge from PetscFE -
>> Fixed 2 mallocs
>> e1648df replace all echo in test/tutorial makefiles with printf since
>> echo behaves differently on different systems
>> bb619f4 DMDA: Missing header - Damn rebase
>> 6de54ef DMPlex ex3: Added 2D Q_1 and 3D P_2 tests
>> 9a800dd DMDA: Added DMDAProjectFunction() and DMDAComputeL2Diff()
>> 3bfb4c2 DMDA: Fixed 2D geometry - Should reuse DMPlex routines
>> 32638f2 DMDA: Fix bug in 2D closure operation for cells
>> a1ac9ad DMDA: Make closure operations also return the size
>> affa55c DMDA: Changed DMDACreateSection() to emulate DMPlexCreateSection()
>> 3385ff7 DMDA: Added functions which emulate DMPlex functionality
>> 3582350 DMDA: Now DMDAGetNumCells() returns the cells in each direction
>> as well
>> that probably shouldn't be in 'master'. They conflict with
>> https://bitbucket.org/petsc/petsc/commits/branch/knepley/feature-dmda-section
>> and potentially other stuff in 'next'. What's with all the working
>> directly on 'master' we're seeing now?
>> - Peter
>> On Mon, Dec 16, 2013 at 12:56 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Sun, Dec 15, 2013 at 9:23 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Matt,
>>>> Is master ahead of next on some code now? I tried to merge a tiny
>>>> change on a branch I just made off of master into next and got this:
>>> Okay, I will fix it. It may take me until tonight since I am in Madison
>>> at a meeting.
>>> I am not sure why Git cannot do this merge, but it should be easy.
>>> Matt
>>>> ~/Src/petsc next $ git merge
>>>> barry/compressed-coloring-only-for-square-matrices
>>>> Auto-merging src/dm/impls/plex/plexrefine.c
>>>> CONFLICT (content): Merge conflict in src/dm/impls/plex/plexrefine.c
>>>> Auto-merging src/dm/impls/plex/plexgeometry.c
>>>> CONFLICT (content): Merge conflict in src/dm/impls/plex/plexgeometry.c
>>>> Auto-merging src/dm/impls/da/dalocal.c
>>>> CONFLICT (content): Merge conflict in src/dm/impls/da/dalocal.c
>>>> Auto-merging src/dm/impls/da/dageometry.c
>>>> CONFLICT (content): Merge conflict in src/dm/impls/da/dageometry.c
>>>> Auto-merging src/dm/dt/interface/dtfe.c
>>>> CONFLICT (content): Merge conflict in src/dm/dt/interface/dtfe.c
>>>> Auto-merging include/petscdmda.h
>>>> CONFLICT (content): Merge conflict in include/petscdmda.h
>>>> Auto-merging config/builder.py
>>>> CONFLICT (content): Merge conflict in config/builder.py
>>>> Automatic merge failed; fix conflicts and then commit the result.
>>>> ~/Src/petsc next|MERGING $ git merge —abort
>>>> Until this is resolved no one can put new things into next
>>>> Thanks
>>>> Barry
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131217/c90a314d/attachment.html>
