[petsc-dev] The question about FD Jacobian
Lulu Liu
lulu.liu at kaust.edu.sa
Fri Dec 6 13:09:50 CST 2013
The Jacobian of the nonlinear system (unknowns are p,s) has the form of J=[
Jpp,Jps;Jsp,Jss].
However, I want to compute each block of Jacobian at different points.
Jpp at x=(p1,s1); Jps at x(p2,s2);
Is it possible to approximate each block (evaluated at different points)
using FD? I have the residual expression for the nonlinear system:
f[j][i].p=....
f[j][i].S=....
Thanks
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131206/634d07a4/attachment.html>
