[petsc-dev] fixing inconsistent right hand side
Wed Dec 4 21:55:33 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Should we add some option to KSP to “fix” the right hand side if it
>    is inconsistent?
Perhaps.
>    Presumably this can be done if we know the null space of A?
The right and left null spaces may not match.
What is a SNES line search going to do when you come out with a step
that is the minimum norm solution to a singular system with an
inconsistent RHS?  (SNES is not going to converge to a small residual or
the minimum norm solution.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131204/8ea3aa08/attachment.sig>
