[petsc-dev] Allocating arrays
Tue Dec 3 13:54:37 CST 2013
Jed Brown <jedbrown at mcs.anl.gov> writes:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>   PetscNew() is PetscCalloc1(1,&beasty); the original analogy with C++
>>   was that it creates a struct and initializes it to zero entries. :-)
> But C++ new does not initialize structs.  It does calls constructors for
> non-POD types.
>>   I’d like to keep it.
> Okay, it becomes
>   PetscNew(&beasty);
'jed/malloc-array' is now pushed to 'next'.  Other people merging to
'next' may encounter compilation errors if they have been using the
original macros.  The commit message contains a shell script that can be
used to convert almost all normal use cases.  Running
  ./malloc-convert.sh src
should be idempotent.  There are two places in include/ that the script
would update, but where I'd rather stick with the original.
Since this change is somewhat disruptive, I would like to merge it to
'master' as soon as possible.  If you are significantly affected by this
change, go ahead and merge 'jed/malloc-array' into your branch, then run
the attached script.
commit 38506d2d16b2b06013b0dc5205b1648e494db573
Merge: 335e720 b00a911
Author: Jed Brown <jedbrown at mcs.anl.gov>
Date:   Tue Dec 3 13:35:29 2013 -0600
    Merge branch 'jed/malloc-array' into next
    * jed/malloc-array:
      Sys: drop explicit type arguments from PetscNew() and PetscNewLog()
      Sys: add PetscCalloc[1-7]
      Sys: add PetscMalloc1 macro, array allocation without redundant types
      PetscMalloc[2-7]: remove type arguments, infer from pointer type
      SNESComputeJacobianDefaultColor: fix uninitialized variable
    Conflicts:
        src/sys/objects/mpinit.c
    cat > malloc-convert.sh <<EOF
    git grep -l PetscMalloc[2-7] $1 | xargs perl -pi \
      -e '
    s at PetscMalloc2\(([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+)\)@PetscMalloc2($1,$3,$4,$6)@;
    s at PetscMalloc3\(([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+)\)@PetscMalloc3($1,$3,$4,$6,$7,$9)@;
    s at PetscMalloc4\(([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+)\)@PetscMalloc4($1,$3,$4,$6,$7,$9,$10,$12)@;
    s at PetscMalloc5\(([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+)\)@PetscMalloc5($1,$3,$4,$6,$7,$9,$10,$12,$13,$15)@;
    s at PetscMalloc6\(([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+)\)@PetscMalloc6($1,$3,$4,$6,$7,$9,$10,$12,$13,$15,$16,$18)@;
    s at PetscMalloc7\(([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+),([^,;()]+)\)@PetscMalloc7($1,$3,$4,$6,$7,$9,$10,$12,$13,$15,$16,$18,$19,$21)@;
    git grep -l 'PetscMalloc(.*sizeof' -- $1 | xargs perl -pi -e 's at PetscMalloc\(([^,;]*[^,; ]) *\* *sizeof\([^,;()]+\), at PetscMalloc1($1,@'
    git grep -l 'PetscNew\(Log\)\?(' -- $1 | xargs perl -pi -e '
    s at PetscNew\([^,;()]+ *, *@PetscNew(@;
    s at PetscNewLog\(([^,;()]+) *,[^,;()]+, *@PetscNewLog($1,@'
    EOF
I have also attached the script.
Type: text/x-sh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131203/b54bef9b/attachment.bin>
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131203/b54bef9b/attachment.sig>
