[petsc-dev] getting rid of TESTEXAMPLES_XXX_XXX stuff
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Dec  3 07:10:12 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>>> runex123: REQUIRE = parmetis mumps 64-bit-indices
>    Ok, I don’t understand this syntax at all, there is no mention of
>    REQUIRE used in this way in the gnumake manual.  How are you
>    proposing to use this variable?
REQUIRE is just a normal (target-specific) variable, it is not
interpreted specially by make.  Consider the attached makefile.
$ make allrun
Creating executable foo.exe
Running runfoo1
Skipping runfoo2 due to unmet requirements: C
Creating executable bar.exe
Running runbar1
rm bar.exe foo.exe
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131203/dcc799d2/attachment.ksh>
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131203/dcc799d2/attachment.sig>
