[petsc-dev] plex failures for 64 bit indices
Barry Smith
bsmith at mcs.anl.gov
Mon Dec 2 20:20:18 CST 2013
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:96:38: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
snum = fscanf(fd, "%d %d\n", &cone[0], &cone[1]);CHKERRQ(snum != numCorners);
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:96:48: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:101:41: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
snum = fscanf(fd, "%d %d %d\n", &cone[0], &cone[1], &cone[2]);CHKERRQ(snum != numCorners);
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:101:51: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:101:61: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:106:44: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
snum = fscanf(fd, "%d %d %d %d\n", &cone[0], &cone[1], &cone[2], &cone[3]);CHKERRQ(snum != numCorners);
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:106:54: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:106:64: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:106:74: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:111:44: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:111:54: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:111:64: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:111:74: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:56: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
snum = fscanf(fd, "%d %d %d %d %d %d %d %d\n", &cone[0], &cone[1], &cone[2], &cone[3], &cone[4], &cone[5], &cone[6], &cone[7]);CHKERRQ(snum != numCorners);
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:66: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:76: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:86: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:96: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:106: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:116: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:116:126: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:138:38: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:138:48: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:143:41: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:143:51: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:143:61: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:148:44: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:148:54: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:148:64: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:148:74: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:153:44: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:153:54: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:153:64: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:153:74: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:56: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:66: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:76: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:86: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:96: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:106: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:116: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:158:126: warning: format specifies type 'int *' but the argument has type 'PetscInt *' (aka 'long long *') [-Wformat]
%lld
/Users/barrysmith/Src/PETSc/src/dm/impls/plex/plexgmsh.c:171:20: warning: argument type 'PetscInt *' (aka 'long long *') doesn't match specified 'MPI' type tag that requires 'int *' [-Wtype-safety]
ierr = MPI_Bcast(&dim, 1, MPI_INT, 0, comm);CHKERRQ(ierr);
