[petsc-dev] finite element energy functions
Jed Brown
jedbrown at mcs.anl.gov
Mon Dec 2 17:45:10 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
>> DMPlexSNESSetFunctionFEM(), similar to DMDASNESSetFunctionLocal in
>> src/snes/examples/tutorials/ex5.c and ex19.c.
> What exactly is the difference?
You have this badly-namespaced, nebulous function called
DMPlexComputeResidualFEM that the user has to pass to
DMSNESSetFunctionLocal and that has to contain a PetscFEM as its first
element. That is grotesque, and binding it from Fortran is needlessly
messy.
Meanwhile, the other function would have an interface something like
DMPlexSNESSetFunctionFEM(DM,PetscFEM);
Note that I would like to get rid of the ugly public struct PetscFEM,
and replace it with a functional interface. In that case, if you
unified the fs and gs, you could have
DMPlexSNESSetFunctionFEM(DM,PetscErrorCode (*f)(...),void *ctx);
DMPlexSNESSetJacobianFEM(DM,PetscErrorCode (*g)(...),void *ctx);
If we want to implicitly sum over multiple functions, the above can be
replaced by arrays of functions, each of which adds some group of terms.
If you do that, there could be a slot for functions computing
intermediate terms (material models), and so on. Eventually, there will
probably need to be another object to manage the dispatch, because we
need the same thing for finite volume and non-Plex things, but I would
try to keep that object private.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/45b92162/attachment.sig>
