[petsc-dev] finite element energy functions
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Dec  2 17:06:47 CST 2013
Geoffrey Irving <irving at naml.us> writes:
> I'm not sure what you mean by the weak form being symmetric, unless
> you mean that the primal and dual spaces are the same, which is just a
> restatement of my question (and therefore I'm not sure in the context
> of petsc).
If my weak form is advection (\int v \cdot \nabla u) then I don't have a
useful energy.  There are lots of things that could cause a stated
"energy" to be nonsense; matching basis functions is just one of them,
and perhaps not even the most common.
> The actual functional in the weak form PDE isn't symmetric except in
> special cases such as Poisson, but presumably that's not what you
> mean.  Indefiniteness is somewhat inevitable (except near well behaved
> extreme solutions), and where it occurs depends on physics.
That sort of indefiniteness doesn't make the energy meaningless, but add
a Lagrange multiplier and the Lagrangian is no longer an energy.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/cc47f2b8/attachment.sig>
