[petsc-dev] finite element energy functions
Jed Brown
jedbrown at mcs.anl.gov
Mon Dec 2 17:01:30 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
> When you and Peter changed the way SNES used to work, I asked you how I
> should
> change Plex. You told me to do this:
> ierr = DMSNESSetFunctionLocal(dm, (PetscErrorCode
> (*)(DM,Vec,Vec,void*)) DMPlexComputeResidualFEM, &user);CHKERRQ(ierr);
> ierr = DMSNESSetJacobianLocal(dm, (PetscErrorCode
> (*)(DM,Vec,Mat,Mat,MatStructure*,void*)) DMPlexComputeJacobianFEM,
Can you find the email? I don't think I would have recommended this.
> which I did. Moreover, this is how it always worked, namely specifying the
> local function.
> What exactly are you proposing to replace this?
DMPlexSNESSetFunctionFEM(), similar to DMDASNESSetFunctionLocal in
src/snes/examples/tutorials/ex5.c and ex19.c.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131202/a10bffcf/attachment.sig>
