[petsc-dev] [PATCH] config: test functions and headers only once
Fri Apr 19 21:11:27 CDT 2013
Many functions and headers are mentioned in both BuildSystem and PETSc,
thus being tested more than once.  Removing this redundancy speeds up my
configure from 125 seconds to 110 seconds.
The full list of redundant configure tests is shown below.
HAVE_LIBLAPACK is anomalous because it is actually testing for different
functions.
$ grep 'Defined .HAVE_' mpich-basic/conf/configure.log | sed 's,^ \+,,' | sort | uniq -cd
      2 Defined "HAVE_ACCESS" to "1"
      2 Defined "HAVE_BZERO" to "1"
      2 Defined "HAVE_CLOCK" to "1"
      2 Defined "HAVE_DLCLOSE" to "1"
      2 Defined "HAVE_DLERROR" to "1"
      2 Defined "HAVE_DLOPEN" to "1"
      2 Defined "HAVE_DLSYM" to "1"
      2 Defined "HAVE_DRAND48" to "1"
      2 Defined "HAVE_ENDIAN_H" to "1"
      2 Defined "HAVE_FCNTL_H" to "1"
      2 Defined "HAVE_FENV_H" to "1"
      4 Defined "HAVE_FLOAT_H" to "1"
      2 Defined "HAVE_FORK" to "1"
      2 Defined "HAVE_GETCWD" to "1"
      2 Defined "HAVE_GETDOMAINNAME" to "1"
      2 Defined "HAVE_GETHOSTBYNAME" to "1"
      2 Defined "HAVE_GETHOSTNAME" to "1"
      2 Defined "HAVE_GET_NPROCS" to "1"
      4 Defined "HAVE_GETPAGESIZE" to "1"
      2 Defined "HAVE_GETPWUID" to "1"
      2 Defined "HAVE_GETRUSAGE" to "1"
      2 Defined "HAVE_GETTIMEOFDAY" to "1"
      2 Defined "HAVE_GETWD" to "1"
      2 Defined "HAVE_LIBBLAS" to "1"
      3 Defined "HAVE_LIBDL" to "1"
     27 Defined "HAVE_LIBLAPACK" to "1"
      5 Defined "HAVE_LIBM" to "1"
      2 Defined "HAVE_LIBZ" to "1"
      2 Defined "HAVE_LIMITS_H" to "1"
      2 Defined "HAVE_LSEEK" to "1"
      2 Defined "HAVE_MALLOC_H" to "1"
      2 Defined "HAVE_MEMALIGN" to "1"
      2 Defined "HAVE_MEMMOVE" to "1"
      2 Defined "HAVE_MEMORY_H" to "1"
      2 Defined "HAVE_MKSTEMP" to "1"
      2 Defined "HAVE_MPI_FINALIZED" to "1"
      2 Defined "HAVE_NETDB_H" to "1"
      2 Defined "HAVE_NETINET_IN_H" to "1"
      2 Defined "HAVE_POPEN" to "1"
      2 Defined "HAVE_PTHREAD_H" to "1"
      2 Defined "HAVE_PWD_H" to "1"
      2 Defined "HAVE_RAND" to "1"
      2 Defined "HAVE_READLINK" to "1"
      2 Defined "HAVE_REALPATH" to "1"
      2 Defined "HAVE_SCHED_H" to "1"
      2 Defined "HAVE_SEARCH_H" to "1"
      2 Defined "HAVE_SETJMP_H" to "1"
      2 Defined "HAVE_SIGACTION" to "1"
      2 Defined "HAVE_SIGNAL" to "1"
      2 Defined "HAVE_SIGSET" to "1"
      2 Defined "HAVE_SLEEP" to "1"
      2 Defined "HAVE_SNPRINTF" to "1"
      2 Defined "HAVE_SOCKET" to "1"
      2 Defined "HAVE_STDINT_H" to "1"
      2 Defined "HAVE_STDLIB_H" to "1"
      2 Defined "HAVE_STRCASECMP" to "1"
      2 Defined "HAVE_STRING_H" to "1"
      2 Defined "HAVE_STRINGS_H" to "1"
      2 Defined "HAVE_SYS_PARAM_H" to "1"
      2 Defined "HAVE_SYS_PROCFS_H" to "1"
      2 Defined "HAVE_SYS_RESOURCE_H" to "1"
      2 Defined "HAVE_SYS_SOCKET_H" to "1"
      3 Defined "HAVE_SYS_SYSINFO_H" to "1"
      2 Defined "HAVE_SYS_TIMES_H" to "1"
      2 Defined "HAVE_SYS_TYPES_H" to "1"
      2 Defined "HAVE_SYS_UTSNAME_H" to "1"
      3 Defined "HAVE_SYS_WAIT_H" to "1"
      3 Defined "HAVE_TIME_H" to "1"
      2 Defined "HAVE_TIMES" to "1"
      2 Defined "HAVE_TIME" to "1"
      2 Defined "HAVE_UNAME" to "1"
      2 Defined "HAVE_UNISTD_H" to "1"
      2 Defined "HAVE_USLEEP" to "1"
After this patch, we have a few "redundant" tests left.
      2 Defined "HAVE_SYS_SYSINFO_H" to "1"
      2 Defined "HAVE_SYS_WAIT_H" to "1"
      2 Defined "HAVE_TIME_H" to "1"
I have not de-duplicated libraries.py yet because it passes in more
structured arguments.  It only runs a few tests multiple times:
[(['socket', 'nsl'], 'socket'), (['fpe'], 'handle_sigfpes'), (['socket', 'nsl'], 'socket'), (['fpe'], 'handle_sigfpes')]
These are actually all defined in one place, but it is visited multiple
times:
  /home/jed/petsc/mpich-basic/conf/reconfigure-mpich-basic.py(12)<module>()
-> configure.petsc_configure(configure_options)
  /home/jed/petsc/config/configure.py(290)petsc_configure()
-> framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions']+sys.argv[1:], loadArgDB = 0)
  /home/jed/petsc/config/BuildSystem/config/framework.py(110)__init__()
-> self.createChildren()
  /home/jed/petsc/config/BuildSystem/config/framework.py(319)createChildren()
-> self.getChild(moduleName)
  /home/jed/petsc/config/BuildSystem/config/framework.py(304)getChild()
-> config.setupDependencies(self)
> /home/jed/petsc/config/PETSc/Configure.py(105)setupDependencies()
-> self.libraries.libraries.extend(libraries1)
  /home/jed/petsc/config/configure.py(293)petsc_configure()
-> framework.configure(out = sys.stdout)
  /home/jed/petsc/config/BuildSystem/config/framework.py(929)configure()
-> self.updateDependencies()
  /home/jed/petsc/config/BuildSystem/config/framework.py(385)updateDependencies()
-> child.setupDependencies(self)
 config/BuildSystem/config/functions.py | 4 ++++
 config/BuildSystem/config/headers.py   | 4 ++++
 2 files changed, 8 insertions(+)
diff --git a/config/BuildSystem/config/functions.py b/config/BuildSystem/config/functions.py
index 30da45e..7b700cb 100644
--- a/config/BuildSystem/config/functions.py
+++ b/config/BuildSystem/config/functions.py
@@ -197,5 +197,9 @@ choke me
       self.executeTest(self.checkSignalHandlerType)
     self.executeTest(self.checkFreeReturnType)
     self.executeTest(self.checkVariableArgumentLists)
+    try:
+      self.functions = list(set(self.functions))
+    except:
+      pass
     map(lambda function: self.executeTest(self.check, function), self.functions)
     return
diff --git a/config/BuildSystem/config/headers.py b/config/BuildSystem/config/headers.py
index e180eaa..f3da45c 100644
--- a/config/BuildSystem/config/headers.py
+++ b/config/BuildSystem/config/headers.py
@@ -230,6 +230,10 @@ class Configure(config.base.Configure):
     self.executeTest(self.checkSysWait)
     self.executeTest(self.checkTime)
     self.executeTest(self.checkMath)
+    try:
+      self.headers = list(set(self.headers))
+    except:
+      pass
     map(lambda header: self.executeTest(self.check, header), self.headers)
     self.executeTest(self.checkRecursiveMacros)
     return
1.8.2.1
