[petsc-dev] OpenCL platform and device query routines
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Apr 12 17:33:56 CDT 2013
What about having threads and OpenCL in the same application?
On Apr 12, 2013 5:31 PM, "Karl Rupp" <rupp at mcs.anl.gov> wrote:
> Hey,
>  Do we want to have a concept, of which opencl, cuda, and threadcomm are
>> instantiations? -device_opencl_view?
> nice idea, sounds a bit like the 'framework' concept in Mac OS. On the
> other hand, the only thing that is common to OpenCL, CUDA, and threadcomm
> is that they aim at parallelism for a single process on a single node (we
> can safely ignore fake environments such as vSMP since we have MPI already).
> Ignoring all existing code for CUDA and OpenCL in PETSc: it might work to
> set up a local communicator concept (i.e. threadcomm extended to CUDA and
> OpenCL) in order to deal with the parallelism. To do so, threadcomm would
> need to be supplemented by an 'offloaded memory' model and should rather be
> called 'localcomm' then (this is supposed to be 'part 2' of my
> yet-to-be-written-and-improved ideas for a unification of these
> approaches). Resulting flags:
>   -localcomm_threads_view
>   -localcomm_opencl_view
>   -localcomm_cuda_view
> Best regards,
> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130412/b1f6587c/attachment.html>
