[petsc-dev] OpenCL platform and device query routines
    Karl Rupp
    rupp at mcs.anl.gov
    Fri Apr 12 16:51:19 CDT 2013
Dear PETScians,
in order to make proper use of OpenCL functionality, we need some
diagnostics for the user such that the correct device is used. Such
functionality is partly also desired for CUDA, but less urgent (only
addresses NVIDIA GPUs anyway).
OpenCL defines platforms (think of it as SDKs from the various vendors)
and devices with one type out of {CPU, GPU, ACCELERATOR}. Each platform
may support multiple devices, but not necessarily all OpenCL-enabled
devices on the machine. For example, the AMD SDK (platform) does not
provide support for NVIDIA GPUs, but it supports Intel CPUs (x86 ftw!).
Since multiple SDKs can be installed in parallel, information on the
proper enumeration is quite important to use the correct device.
Example: A machine equipped with an Intel CPU and an NVIDIA GPU with
OpenCL SDKs from Intel, AMD, and NVIDIA installed. Within OpenCL one
will 'see' the following:
- Platform 0:
   - Vendor: Intel
   - Device 0: Intel i7 whatever (CPU)
- Platform 1:
   - Vendor: AMD
- Platform 2:
   - Vendor NVIDIA
   - Device 0: NVIDIA GTX whatever (GPU)
(Maybe in different order. Matters can get worse with Xeon Phi, AMD
APUs, etc.)
To provide the necessary diagnostics, I suggest in line with -vec_view
the flag
   -opencl_view
to print the OpenCL infrastructure available on the system.
Is there any better naming scheme/proposal? -cuda_view and maybe some
time later -threadcomm_view (-numa_view?) would follow from this choice.
Note that this should be independent of external linear algebra
libraries such as CUSP, ViennaCL, etc. to avoid unnecessary code
duplication. However, the actual platform/device *setter* flags (e.g.
pick device 0 from platform 1) need to be package-specific.
Best regards,
Karli
