[petsc-dev] Fwd: [petsc-users] cannot find 'libz.a' when configuring
    Satish Balay
    balay at mcs.anl.gov
    Thu Apr 11 10:25:33 CDT 2013
On Thu, 11 Apr 2013, Matthew Knepley wrote:
> On Thu, Apr 11, 2013 at 10:12 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Thu, 11 Apr 2013, Satish Balay wrote:
> > > > > > > > We have had this same discussion a million times, and we always
> > > > > > > eventually
> > > > > > > > get to the same answer and forget. Do we need our own error
> > message
> > > > > for
> > > > > > > > petsc-dev?
> > > > > > > > We cannot possibly guess everything that can go wrong. What we
> > need
> > > > > is a
> > > > > > > > system
> > > > > > > > where the user can specify what he actually wants and we check
> > it.
> > > > > So,
> > > > > > > zlib
> > > > > > > > and
> > > > > > > > everything else are optional dependencies for hdf5. If
> > something is
> > > > > not
> > > > > > > > specified, it
> > > > > > > > fails, and the user goes back and specifies the right thing.
> > > > > > > Sure - but specify how? specify everything with
> > > > > > > --with-hdf5-lib,--with-hdf5-include options?
> > > > > > > Or somehow he knows that he has to specify
> > > > > > > --with-zlib-include/-with-zlib-lib options?
> > > > > > This. It would be nice if HDF5 would tell us about its
> > dependencies, but
> > > > > if
> > > > > > it does not, then
> > > > > > the user has to, and this is our system (packages).
> > > > > So we would start adding zlib.py, szip.py and manymore [and support
> > > > > --download-zlib --download-szip]. And if user gets the error:
> > > > > --with-hdf5-dir=/foo/bar does not work.
> > > > > So he/she send us configure.log
> > > > > Then we look at it and respond saying: you need to specify
> > --with-zlib-dir
> > > > > --with-szip-dir options aswell.
> > > > > Does this look right?
> > > > Yes, that is what I think makes sense.
> > > > We can always try to add another layer that 'greps' for libz in the
> > hdf5
> > > > error message and guesses that
> > > > the user forgot it, but hopefully before we get to it, a sane storage
> > > > library appears, or HDF5 gets its act
> > > > together.
> > > In this case - why bother with libz.py and szip.py? Why not tell the
> > > user to specify hdf5 completely with --with-hdf5-include and
> > > --with-hdf5-lib options?
> > > Just printing the link errors on the screen might be sufficient to
> > > clue in the user. Currently its hidden inside configure. [And its not
> > > clear which of the 10 tests configure did for this case should be
> > > printed on the screen as the appropriate message]
> > I might have been the one that advocated self.needsCompression approach
> > thats
> > currently in configure.
> > This is currently used only by hdf5.py.
> > My current thought is to strip it out - and just add it to hdf5.py as:
> >     self.liblist   =
> > [['libhdf5.a','libhdf5_hl.a'],'['libhdf5.a','libhdf5_hl.a','libz.a'],['libhdf5.a','libhdf5_hl.a','zlib.lib']]
> > This would be equivalent to the current functionality - and perhaps
> > what was there previously - before we wanted better error messages and
> > detection of zlib. Since this is not possible anyway why bother
> > with the additional complexity?
> What is not possible? Detecting zlib? Of course this is possible, and we do
> it.
The primary thing we need is detecting hdf5 provided by user requires
zlib [and or szip]. This is not poissible.
And current code can't detect zlib anyway [outside system locations]
so we need libz.py to detect it better.  But whats the point of it?
[detecting zlib or szip via --with-zlib-dir and --with-szip-dir options?]
When use has a mesages:
--with-hdf5=foo/bar provides does not work
I'd rather respond with:
Specify hdf5 and all its dependencies correctly with
--with-hdf5-lib,--with-hdf5-include options.
> It is not possible to know without testing what crazy link line is
> required by HDF5, at least I don't know how to do that.
yes
> This is no way affects the utility of testing for zlib.
But whats the point of testing for zlib - if not for hdf5? And if we
can't relate them automatically.
Satish
