[petsc-dev] PetscStackCall() and CHKMEMQ
Jed Brown
jedbrown at mcs.anl.gov
Mon Apr 1 11:33:20 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> Is the only issue that PetscStackCall() has a CHKMEMQ() within it?
Yes, that's the only problem I have.
> Otherwise it seems PetscStackCall() costs no more than any other
> PETSc function call with PetscFunctionBegin/Return(). Perhaps it
> could take a flag argument indicating if the memory check should be
> performed? For BLAS/LAPACK assuming we've allocated enough work
> space the memory check is likely not needed, should we have a
> PetscStackCallBLASLAPACK() (that possibly even handles the info
> flag when it exists?) which does not do a CHKMEMQ?
At present, BLAS/LAPACK is the only case I noticed where PetscStackCall
was used in a perf-sensitive place so I think PetscStackCallBLASLAPACK
is fine. Do you really want a macro that checks the error code too?
