[petsc-dev] Preprocessor hell: #define VecType
Karl Rupp
rupp at mcs.anl.gov
Fri Sep 28 11:59:01 CDT 2012
> You are missing the fact that all PetscObjects have an implementation
> type and it is a string, and there is
> one of these #defines for every class.
Ok, thanks for shedding light on that.
> However, I would support namespacing all these Types since they are not
> in heavy use, e.g. PetscVecType, PetscMatType.
I assume that any compiler errors would be a LOT clearer if VecType were
at least a typedef instead of a brutal preprocessor-define. Without
having checked the following,
#define VecType PetscVecType
typedef char* PetscVecType;
may already improve the situation substantially. Removing any
preprocessor activity on the string/type 'VecType' would be the cleaner
approach, though...
Best regards,
Karli
