[petsc-dev] Preprocessor hell: #define VecType
Karl Rupp
rupp at mcs.anl.gov
Fri Sep 28 11:25:51 CDT 2012
Hi guys,
a long time ago, I stumbled upon one thing that caused a lot of
headaches when interfacing my code with PETSc. Stripping away all the
details, my solver interface looked about like this:
template <typename MatrixType, typename VecType>
VecType solve(MatrixType const & A, VecType const & b);
Everything went well if PETSc was not in use. However, I got really
weird compiler errors as soon as I've included petscksp.h.
Now, fast-forward to today. While browsing through the existing
CUDA-enabled implementations, I found the following in
src/ksp/pc/impls/sacusp.cu:
#undef VecType
#include <cusp/precond/smoothed_aggregation.h>
#define VecType char*
While this preprocessor define is inside an implementation file, not in
a header file, one may consider that acceptable.
However, a quick grep on the main include/ folder reveals
petscvec.h:#define VecType char*
which is ultimately the reason why my template code went nuts. While I
do understand that name clashes can appear, I tried to find the deeper
meaning of VecType. The manual lists only one reference on page 170:
VecLoad(PetscViewer viewer,VecType outtype,Vec *newvec);
and the associated hyperlink
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Vec/VecLoad.html#VecLoad
points to an HTML page defining the prototype
#include "petscvec.h"
PetscErrorCode VecLoad(Vec newvec, PetscViewer viewer)
This suggests that VecType is not in use here, and it may not be in
serious use at all. I can find about five uses of VecType in the whole
include/-folder, so it shouldn't be too hard to get rid of that (e.g. by
renaming to PetscVecType or any other more descriptive name), should it?
Do I miss something?
Best regards,
Karli
PS: For reference, the following code compiles and prints "Hello World!":
#include <iostream>
#include "petscksp.h"
int main(int argc, char **args)
VecType test = "Hello world!";
std::cout << test << std::endl;
return EXIT_SUCCESS;
To eliminate any warnings about deprecated conversion of strings, just
add 'const' in front of 'VecType'.
