[petsc-dev] GAMG MatSetValues error
    John Mousel
    john.mousel at gmail.com
    Tue Sep 25 07:49:58 CDT 2012
Matt,
It's not technically an error. It's an inefficient preallocation. I'm
assuming Mark doesn't want this to be happening.
[0] PCSetUp(): Setting up new PC
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374777
[2] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374780
[1] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374780
[3] PetscCommDuplicate(): Using internal PETSc communicator 1140850689
-2080374780
-2080374777
-2080374780
-2080374780
-2080374780
[1] MatAssemblyBegin_MPIAIJ(): Stash has 1830 entries, uses 0 mallocs.
[3] MatAssemblyBegin_MPIAIJ(): Stash has 914 entries, uses 0 mallocs.
[2] MatAssemblyBegin_MPIAIJ(): Stash has 1991 entries, uses 0 mallocs.
[0] MatStashScatterBegin_Private(): No of messages: 3
[0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 16200
[0] MatStashScatterBegin_Private(): Mesg_to: 2: size: 4192
[0] MatStashScatterBegin_Private(): Mesg_to: 3: size: 1800
[0] MatAssemblyBegin_MPIAIJ(): Stash has 2771 entries, uses 0 mallocs.
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 10840 X 10840; storage space: 0
unneeded,119860 used
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 26
[2] Mat_CheckInode(): Found 10840 nodes out of 10840 rows. Not using Inode
routines
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 10862 X 10862; storage space: 0
unneeded,117330 used
[3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 26
[3] Mat_CheckInode(): Found 10862 nodes out of 10862 rows. Not using Inode
routines
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 12138 X 12138; storage space: 0
unneeded,116975 used
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 26
[1] Mat_CheckInode(): Found 12138 nodes out of 12138 rows. Not using Inode
routines
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10765 X 10765; storage space: 0
unneeded,110555 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 25
[0] Mat_CheckInode(): Found 10765 nodes out of 10765 rows. Not using Inode
routines
-2080374780
-2080374780
-2080374780
-2080374777
-2080374777
-2080374780
-2080374780
-2080374780
[0] VecScatterCreateCommon_PtoS(): Using blocksize 1 scatter
[0] VecScatterCreate(): General case: MPI to Seq
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 10840 X 566; storage space:
118775 unneeded,1100 used
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 1
[2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 10
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 10862 X 259; storage space:
116725 unneeded,650 used
[3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 3
[3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 11
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10765 X 1295; storage space:
107825 unneeded,3165 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 29
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 12138 X 1131; storage space:
114609 unneeded,2591 used
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 15
[1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 13
John
On Tue, Sep 25, 2012 at 5:41 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Sep 24, 2012 at 9:48 PM, John Mousel <john.mousel at gmail.com>wrote:
>> I'm having a problem with GAMG causing a MatSetValues() is [some non-zero
>> number] after
> I do not see any errors in your output.
>   Matt
>>  I don't get this with either ILU or HYPRE/BoomerAMG. I've attached the
>> output of -info. I see there is a recent change to some pre-allocation for
>> GAMG here:
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/fe806009181b
>> I'm not sure if that has anything to do with it, but my blocksize is 1.
>> I'm running with the following options.
>> -ksp_type bcgsl -pc_type gamg -pc_gamg_threshold 0.01 -mg_levels_ksp_type
>> richardson -mg_levels_pc_type sor -mg_coarse_ksp_type richardson
>> -mg_coarse_pc_type sor -mg_coarse_pc_sor_its 4 -pc_gamg_type agg
>> -pc_gamg_agg_nsmooths 1 -pc_gamg_sym_graph true -info
>> -ksp_monitor_true_residual
>> Thanks,
>> John
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120925/558fdcc2/attachment.html>
