[petsc-dev] Enabling single precision for MUMPS and SUPERLU
Hong Zhang hzhang at mcs.anl.gov
Mon Sep 24 10:55:39 CDT 2012
Stefano :
I tested the patch with
single and double precision, double with '--with-scalar-type=complex'
All passed.
The patches are pushed to petsc-dev
(http://petsc.cs.iit.edu/petsc/petsc-dev/)
Thanks for your contribution!
Hong
Sorry Hong, I forgot to pull before doing the patches. Please find attached
> the patches made with the latest dev
> (changeset 24444 92061a43c7a4)
> Stefano
> 2012/9/21 Hong Zhang <hzhang at mcs.anl.gov>
>> Stefano:
>> Are you sure these patches are made out of the latest petsc-dev?
>> I get
>> petsc:/sandbox/hzhang/petsc-dev>patch -Np1 < superlu_patch_single.diff
>> patching file config/PETSc/packages/SuperLU.py
>> patching file src/mat/impls/aij/seq/superlu/makefile
>> patching file src/mat/impls/aij/seq/superlu/superlu.c
>> Hunk #1 FAILED at 21.
>> Hunk #2 FAILED at 142.
>> Hunk #4 FAILED at 311.
>> Hunk #5 succeeded at 517 with fuzz 2.
>> Hunk #6 FAILED at 569.
>> Hunk #8 succeeded at 618 with fuzz 1.
>> 4 out of 8 hunks FAILED -- saving rejects to file
>> src/mat/impls/aij/seq/superlu/superlu.c.rej
>> Similar error on mumps_patch_single.diff.
>> Patching petsc-3.3 is successful though.
>> Barry: do you agree with Stefano's approach?
>> Hong
>> Hong, attached please find the two patches split.
>>>> Stefano:
>>>>> When Hong has finished testing, I will split the patches and commit
>>>>> them. Please let me know what macro name you'll choose (or the ugly choice
>>>>> of course)
>>>> How about split the patches now?
>>>> Then I'll test one package at a time.
>>>> Hong
>>>>> There is also pastix which can be enabled, but the problem is that it
>>>>> requires pt-scotch for partitioning, and in turn pt-scotch will become a
>>>>> possible method to be used in MatPartitioning class. Maybe someone can
>>>>> think about adding a new command line argument in package configure which
>>>>> guaranties you will use a library (pt-scotch) only inside  pastix and not
>>>>> within the MatPartitioning class? (maybe using self.useddirectly in
>>>>> config/BuildSystem/package.py)
>>>>> Stefano
>>> Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120924/38a44f30/attachment.html>
