[petsc-dev] Enabling single precision for MUMPS and SUPERLU
    Hong Zhang
    hzhang at mcs.anl.gov
    Fri Sep 21 16:48:25 CDT 2012
Stefano:
Are you sure these patches are made out of the latest petsc-dev?
I get
petsc:/sandbox/hzhang/petsc-dev>patch -Np1 < superlu_patch_single.diff
patching file config/PETSc/packages/SuperLU.py
patching file src/mat/impls/aij/seq/superlu/makefile
patching file src/mat/impls/aij/seq/superlu/superlu.c
Hunk #1 FAILED at 21.
Hunk #2 FAILED at 142.
Hunk #4 FAILED at 311.
Hunk #5 succeeded at 517 with fuzz 2.
Hunk #6 FAILED at 569.
Hunk #8 succeeded at 618 with fuzz 1.
4 out of 8 hunks FAILED -- saving rejects to file
src/mat/impls/aij/seq/superlu/superlu.c.rej
Similar error on mumps_patch_single.diff.
Patching petsc-3.3 is successful though.
Barry: do you agree with Stefano's approach?
Hong
Hong, attached please find the two patches split.
> 2012/9/21 Hong Zhang <hzhang at mcs.anl.gov>
>> Stefano:
>>> When Hong has finished testing, I will split the patches and commit
>>> them. Please let me know what macro name you'll choose (or the ugly choice
>>> of course)
>> How about split the patches now?
>> Then I'll test one package at a time.
>> Hong
>>> There is also pastix which can be enabled, but the problem is that it
>>> requires pt-scotch for partitioning, and in turn pt-scotch will become a
>>> possible method to be used in MatPartitioning class. Maybe someone can
>>> think about adding a new command line argument in package configure which
>>> guaranties you will use a library (pt-scotch) only inside  pastix and not
>>> within the MatPartitioning class? (maybe using self.useddirectly in
>>> config/BuildSystem/package.py)
>>> Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120921/65a46ca2/attachment.html>
