[petsc-dev] Recover SNES ex6.c?
Jed Brown
jedbrown at mcs.anl.gov
Wed Sep 19 18:29:41 CDT 2012
I might put the functionality into ex2.c (more intrusive, as you say), but
I don't mind restoring ex6.c.
On Sep 19, 2012 4:48 PM, "Karl Rupp" <rupp at mcs.anl.gov> wrote:
> Hi,
> as I just noticed, src/snes/examples/tutorials/**ex6.c was kicked out two
> days ago: http://petsc.cs.iit.edu/petsc/**petsc-dev/rev/cb006da503e9<http://petsc.cs.iit.edu/petsc/petsc-dev/rev/cb006da503e9>
> However, ex6.c is included in the user manual, now causing the compilation
> to fail. With ex6.c containing matrix-free Jacobians, which are not
> included in ex2.c, the respective section in the manual would require
> considerable rewriting. Conversely, merging the matrix-free stuff from
> ex6.c to ex2.c is not an option either, as ex2.c is used elsewhere in the
> manual, leading to a fairly non-intuitive documentation. Any ideas aside
> from recovering ex6.c?
> Best regards,
> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120919/0cb3553b/attachment.html>
