[petsc-dev] Bad fortran interface generations
    Stefano Zampini
    stefano.zampini at gmail.com
    Tue Sep 18 16:16:52 CDT 2012
You're right. I'll report the problem to the admins.
2012/9/18 Barry Smith <bsmith at mcs.anl.gov>
>    /usr/local/bin/bfort must be the old one that continued lines that
> exactly fit and thus confused the bg compiler.
>    the --download brings down the latest sowing with the fix for continued
> lines.
>     Barry
> Someone should remove the  /usr/local/bin. one.
> On Sep 18, 2012, at 1:37 PM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> > externalpackages/sowing* is empty in my broken source. Bgq has bfort in
> /usr/local/bin. actual petsc-dev version recognized it and thus use it.
> > I switched to require --download-sowing in configure and this solves the
> problem. There was any change in config related to don't use sowing by
> default recently?
> > Thanks,
> > Stefano
> > 2012/9/18 Satish Balay <balay at mcs.anl.gov>
> > Can you do rm -rf externalpackages/sowing* and rerun configure - and
> > see if the problem persists?
> > Satish
> > On Tue, 18 Sep 2012, Stefano Zampini wrote:
> > > Something is changed between HG revision
> > > ce7508606e824d026ea20d05da900e98f37b3864 and the current tip which
> affected
> > > the automatic generation of Fortran Interfaces.
> > > In particular, PETSc-dev compilation is now broken on some .h90 headers
> > > created in include/finclude/ftn-auto/.
> > > For example, in include/finclude/ftn-auto/petscvec.h90 for the current
> tip
> > >         subroutine VecGhostUpdateBegin(g, insertmode, scattermode
> ,ierr)&
> > > whereas for ce7508606e824d026ea20d05da900e98f37b3864
> ,ierr)
> > > The form with ampersand is a sintax error for bgxlf90. Removing the two
> > > ampersands solves the problem.
> "/fermi/home/userprod/propro01/szampini/petsc-dev/include/finclude/petscvec.h90",
> > > line 9.7: 1515-019 (S) Syntax is incorrect.
> "/fermi/home/userprod/propro01/szampini/petsc-dev/src/vec/f90-mod/petscvecmod.F",
> > > line 25.8: 1513-085 (S) Improper END statement specified. This END
> > > statement will be matched with the program unit or procedure named
> _main.
> > > ** _main   === End of Compilation 138 ===
> > Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120918/d6b7cae5/attachment.html>
