[petsc-dev] Bad fortran interface generations
Satish Balay
balay at mcs.anl.gov
Tue Sep 18 10:53:39 CDT 2012
Can you do rm -rf externalpackages/sowing* and rerun configure - and
see if the problem persists?
Satish
On Tue, 18 Sep 2012, Stefano Zampini wrote:
> Something is changed between HG revision
> ce7508606e824d026ea20d05da900e98f37b3864 and the current tip which affected
> the automatic generation of Fortran Interfaces.
> In particular, PETSc-dev compilation is now broken on some .h90 headers
> created in include/finclude/ftn-auto/.
> For example, in include/finclude/ftn-auto/petscvec.h90 for the current tip
> subroutine VecGhostUpdateBegin(g, insertmode, scattermode ,ierr)&
> whereas for ce7508606e824d026ea20d05da900e98f37b3864
> The form with ampersand is a sintax error for bgxlf90. Removing the two
> ampersands solves the problem.
> "/fermi/home/userprod/propro01/szampini/petsc-dev/include/finclude/petscvec.h90",
> line 9.7: 1515-019 (S) Syntax is incorrect.
> "/fermi/home/userprod/propro01/szampini/petsc-dev/src/vec/f90-mod/petscvecmod.F",
> line 25.8: 1513-085 (S) Improper END statement specified. This END
> statement will be matched with the program unit or procedure named _main.
> ** _main === End of Compilation 138 ===
