[petsc-dev] plans for testing examples?
Barry Smith
bsmith at mcs.anl.gov
Mon Sep 17 09:08:19 CDT 2012
On Sep 16, 2012, at 10:46 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sun, Sep 16, 2012 at 10:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> What are the various plans for running the test cases on examples?
> As I've said before I'd really like each example to be self-contained which means its tests and its test results would all sit in the same file (so, for example, the file could trivially be moved to another directory location and the tests still work). One way to do this is to have each example file to have a chunk of python code after the source that ran all the tests and then after that a chunk of all the outputs. Having the test cases inside the makefile (or in some directory or gasp "single location specific file) and the output files in the output directory is, to me, not desirable.
> It sounds like you are asking for something like Python's doctest for executables.
> http://docs.python.org/library/doctest.html
> If the output was feasibly short, we could build a system this way.
> Jed, what is your horrible plan?
> I wrote a parser for our makefile-based tests. It currently creates files that describe tests like this:
> with Executable('ex15.c', libs='PETSC_TS_LIB'):
> Test(id='1', args='-da_grid_x 20 -da_grid_y 20 -boundary 0 -ts_max_steps 10')
> Test(id='2', args='-da_grid_x 20 -da_grid_y 20 -boundary 0 -ts_max_steps 10 -Jtype 2', compare='ex15_1')
> Test(id='3', args='-da_grid_x 20 -da_grid_y 20 -boundary 1 -ts_max_steps 10')
> Test(id='4', np=2, args='-da_grid_x 20 -da_grid_y 20 -boundary 1 -ts_max_steps 10')
> Test(id='5', args='-da_grid_x 20 -da_grid_y 20 -boundary 0 -ts_max_steps 10 -Jtype 1', compare='ex15_1')
How do you map the loops in some of the shell scripts in the makefiles?
> I would the "id" field to use more descriptive names when appropriate so these numbers are just the inherited names. This snippet of Python registers the executable and the associated tests in a global index (will probably make at a sqlite database). The test result can be reported back to the database. I wrote most of a parallel executor with active progress monitoring, similar to nose-progressive, but not all the pieces are playing nicely together yet.
> Me eventual plan is to be able to batch up the test results, which will include basic timing information, and report it back to a central server so we can keep a log. That could be done with buildbot or Jenkins, which fulfill most of our needs for a "dashboard", but lack a good database query API.
> Test specification, which seems to be what you are most concerned with, could also be via "doctests". The main thing is that if you execute the test script, it first updates its database with all executables and tests in subdirectories (specified any way we like), then does whatever operations you ask for (building, testing, etc).
Where are your magic scripts?
What if I proposed moving the Test(id='2', args='-da_grid_x 20 -da_grid_y 20 -boundary 0 -ts_max_steps 10 -Jtype 2', compare='ex15_1') type data into the examples and generating the makefiles for the example directories automatically? Then we'd have one set of scripts that could scarf info from the examples and it would put it into several formats.
Barry
> Matt, what is your horrible plan?
> Can we converge to something agreeable to all?
> Barry
