[petsc-dev] making Beamer easier to start than Powerpoint
Matthew Knepley
knepley at gmail.com
Sat Sep 8 16:54:02 CDT 2012
On Sat, Sep 8, 2012 at 4:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 8, 2012, at 2:09 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > On Sat, Sep 8, 2012 at 12:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Yes, because this is how people prepare talks. They grab slides and
> partial slides and formats for slides from a variety of previous
> presentations and stick them together in the order they want, and make some
> new slides (often by copying a previous one and changing this in it; for
> example most people use Duplicate_Slide in Powerpoint to start a new slide,
> not New_Slide).
> > Now if you could come up with a "library" way to do pretty much the same
> process that moved from "templates" to "libraries" that would be great,
> but I don't see how to do this, do you?
> > Matt and I have repositories containing a bunch of slides. Our talks
> \input{} a bunch of those slides. For each new talk, I make new slides for
> the new topics and reuse or improve slides for existing topics. Since there
> is only one copy of each slide, the bug fixes are applied to the right
> place so I don't have to worry about copying a slide from an old talk where
> bugs have not been fixed.
> > If I know that I want a truly custom version of a slide, I just copy it
> into the main document. Sometimes I change my mind later and extract slides
> from old talks into separate slide files.
> > Thus I would be happy if I had about 20 beamer template slides with
> different organizations (a simple bulleted list, a could of pictures, two
> parallel bulleted lists, a bar plot, ….) as I prepare slides I would just
> grab the appropriate template and modify it.
> > https://github.com/jedbrown/talks ?
> Excellent! Thanks.
https://bitbucket.org/aterrel/presentations
Matt
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120908/eaf49015/attachment.html>
