[petsc-dev] ierr and CHKERRQ stuff
Anton Popov popov at uni-mainz.de
Tue Oct 30 08:06:29 CDT 2012
Good idea, I will use PETSC_CALL instead
On 10/30/12 1:52 PM, Karl Rupp wrote:
> Hi Vaclav,
> you are of course free to define TRY for your needs. Defining a short
> TRY globally in a *library*, however, is pretty dangerous, as the
> preprocessor define may collide with existing user definitions of TRY.
> Using PETSC_TRY instead of TRY might 'solve' this first problem, yet
> the example
> >    if (something) TRY( somefun1 );
> >    else           TRY( somefun2 );
> you provided is (at least in my opinion) reason enough not to do it. :-)
> Btw: For technical reasons you might want to instantiate 'ierr' inside
> TRY, otherwise 'ierr' needs to be defined in the enclosing scope, even
> though it appears to be never used when looking at the user code.
> Maybe there are other reasons as well? Barry?
> Best regards,
> Karli
> On 10/30/2012 04:27 AM, Václav Hapla wrote:
>> Dear all,
>> I probably don't see something important and I am sorry for that in
>> advance, but anyway I want to make it clear to me:
>> What would I spoil by using kind of
>>    TRY( ... );
>> concept instead of
>>    ierr = ...;CHKERRQ(ierr);
>> stuff?
>> The first concept seems to me making the code more readable and is
>> faster to type of course.
>> I have the following two lines in one of my headers included by all C
>> files:
>>    static PetscErrorCode ierr;
>>    #define TRY(f) {ierr = f; CHKERRQ(ierr);}
>> and the PETSc' error catching system works normally I mean.
>> I know of course that for instance following is wrong:
>> which is a little bit nonintuitive.
>> This is not against already existing code; I would just like to
>> understand the reasons - if I am wrong I am about to switch my codebase
>> to the original PETSc' concept.
>> Thanks in advance,
>> BR,
>> Vaclav
