[petsc-dev] Implementing the Fortran interface for DMSHELL
Richard Tran Mills rtm at eecs.utk.edu
Fri Oct 26 15:42:16 CDT 2012
Hi Guys,
I want to take a stab at implementing the necessary custom Fortran stubs
so that I can use DMSHELL from inside PFLOTRAN.  I have a couple of dumb
questions:
1) I used to know this: How do I mark a routine in the code as one that
requires a custom stub vs. one that can use an auto-generated one?  Is
this just a matter of having "/*@C" vs "/*@" in the comment before the
function definition?  Do I need to do something else?
2) Should I create a test case for this that does something like, say,
create "shell" routines that actually just do something like call the DMDA
ones?  Where should this test go?
Richard
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
