[petsc-dev] Status of pthreads and OpenMP support
Thu Oct 25 20:16:54 CDT 2012
On Thu, Oct 25, 2012 at 8:05 PM, John Fettig <john.fettig at gmail.com> wrote:
> What I see in your results is about 7x speedup by using 16 threads.  I
> think you should get better results by running 8 threads with 2
> processes because the memory can be allocated on separate memory
> controllers, and the memory will be physically closer to the cores.
> I'm surprised that you get worse results.
Our intent is for the threads to use an explicit first-touch policy so that
they get local memory even when you have threads across multiple NUMA zones.
> It doesn't surprise me that an explicit code gets much better speedup.
The explicit code is much less dependent on memory bandwidth relative to
floating point.
> > I also get about the same performance results on the ex2 problem when
> running it with just
> > mpi alone i.e. with 16 mpi processes.
> > So from my perspective, the new pthreads/openmp support is looking
> pretty good assuming
> > the issue with the MKL/external packages interaction can be fixed.
> > I was just using jacobi preconditioning for ex2.  I'm wondering if there
> are any other preconditioners
> > that might be multi-threaded.  Or maybe a polynomial preconditioner
> could work well for the
> > new pthreads/openmp support.
> GAMG with SOR smoothing seems like a prime candidate for threading.  I
> wonder if anybody has worked on this yet?
SOR is not great because it's sequential. A block Jacobi/SOR parallelizes
fine, but does not guarantee stability without additional
(operator-dependent) damping. Chebyshev/Jacobi smoothing will perform well
with threads (but not all the kernels are ready).
Coarsening and the Galerkin triple product is more difficult to thread.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121025/e72b68e8/attachment.html>
