[petsc-dev] corrupted ta->count with GAMG
John Mousel
john.mousel at gmail.com
Thu Oct 25 11:37:37 CDT 2012
Mark,
I'll try to get you some numbers on this. One quick question. Is it
possible to use
-pc_ml_CoarsenScheme METIS
I've tried, but I get an error message.
*ML*WRN* This function has been compiled without the configure
*ML*WRN* option --with-ml_metis
*ML*WRN* I will put all the nodes in the same aggregate, this time...
*ML*WRN* (file ./Coarsen/ml_agg_METIS.c, line 966)
I'm about to build, and I didn't know if I'm missing an option that I need.
John
On Thu, Oct 25, 2012 at 10:24 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> On Oct 25, 2012, at 7:30 AM, John Mousel <john.mousel at gmail.com> wrote:
> That was my first thought as well. I was hoping the changes he made would
> have brought down GAMG's setup cost some as right now GAMG isn't
> competetive with ML because my matrix numbering changes every time step.
> Yes, our setup times need work.
> I get much better performance from GAMG after the setup
> phase...unfortunately that does me no good!
> ML can get the same performance as GAMG, they are very similar algorithms.
> Are your convergence rates better or is the timing just better?
> John
> On Thu, Oct 25, 2012 at 9:23 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> The problem is detected in MatTranspose and Jed was messing with this a
>> few weeks ago ...
>> On Oct 25, 2012, at 6:48 AM, John Mousel <john.mousel at gmail.com> wrote:
>> Mark,
>> Yes, this worked before pulling. I hadn't pulled on that machine in a few
>> weeks though.
>> John
>> On Thu, Oct 25, 2012 at 1:18 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>>> Did this work before the pull?
>>> Mark
>>> On Oct 24, 2012, at 8:04 PM, John Mousel <john.mousel at gmail.com> wrote:
>>> > I just pulled and I'm getting the error below when running with GAMG.
>>> > [20]PETSC ERROR: --------------------- Error Message
>>> > [20]PETSC ERROR: Corrupted Petsc object!
>>> > [20]PETSC ERROR: corrupted ta->count!
>>> > [20]PETSC ERROR:
>>> > [20]PETSC ERROR: Petsc Development HG revision:
>>> 2b3cccd7bd8ff536f48616e4402b164ba9cd12d0 HG Date: Wed Oct 24 21:15:30 2012
>>> -0500
>>> > [20]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> > [73]PETSC ERROR: [20]PETSC ERROR: --------------------- Error Message
>>> > See docs/faq.html for hints about trouble shooting.
>>> > [73]PETSC ERROR: [20]PETSC ERROR: See docs/index.html for manual pages.
>>> > [20]PETSC ERROR: [73]PETSC ERROR:
>>> > [253]PETSC ERROR: --------------------- Error Message
>>> > [253]PETSC ERROR: Corrupted Petsc object!
>>> > [253]PETSC ERROR: corrupted ta->count!
>>> > [253]PETSC ERROR:
>>> > [253]PETSC ERROR: Petsc Development HG revision:
>>> -0500
>>> > [253]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> > [253]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> > [253]PETSC ERROR: See docs/index.html for manual pages.
>>> > [253]PETSC ERROR:
>>> > [253]PETSC ERROR: /nfsscratch/Users/jmousel/MHV/MHV_exe on a intel-opt
>>> named compute-6-165.local by jmousel Wed Oct 24 21:59:50 2012
>>> > [253]PETSC ERROR: Libraries linked from
>>> /Users/jmousel/SOFT/petsc-dev/intel-opt/lib
>>> > [253]PETSC ERROR: Configure run at Wed Oct 24 21:41:09 2012
>>> > [253]PETSC ERROR: Configure options --download-blacs=1
>>> --download-cmake=1 --download-hypre=1 --download-metis=1 --download-ml=1
>>> --download-parmetis=1 --download-scalapack=1
>>> --with-blas-lapack-dir=/opt/intel/mkl/10.2.5.035/lib/em64t--with-debugging=0 --with-mpi-dir=/opt/openmpi/1.4.3/intel COPTFLAGS=-O2
>>> FOPTFLAGS=-O2 PETSC_ARCH=intel-opt
>>> > [253]PETSC ERROR:
>>> > [253]PETSC ERROR: PetscTableAddExpand() line 145 in
>>> src/sys/utils/ctable.c
>>> > [253]PETSC ERROR: PetscTableAdd() line 75 in
>>> src/sys/sf//Users/jmousel/SOFT/petsc-dev/include/petscctable.h
>>> > [253]PETSC ERROR: PetscSFSetGraph() line 327 in src/sys/sf/sf.c
>>> > [253]PETSC ERROR: PetscSFSetGraphLayout() line 595 in
>>> src/vec/vec/impls/mpi/pmap.c
>>> > [253]PETSC ERROR: MatTranspose_MPIAIJ() line 2130 in
>>> src/mat/impls/aij/mpi/mpiaij.c
>>> > [253]PETSC ERROR: MatTranspose() line 4350 in
>>> src/mat/interface/matrix.c
>>> > [253]PETSC ERROR: PCGAMGFilterGraph() line 136 in
>>> src/ksp/pc/impls/gamg/tools.c
>>> > [253]PETSC ERROR: PCGAMGgraph_AGG() line 979 in
>>> src/ksp/pc/impls/gamg/agg.c
>>> > [253]PETSC ERROR: PCSetUp_GAMG() line 685 in
>>> src/ksp/pc/impls/gamg/gamg.c
>>> > [253]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
>>> > [253]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
>>> > [253]PETSC ERROR: KSPSolve() line 402 in src/ksp/ksp/interface/itfunc.c
>>> > /nfsscratch/Users/jmousel/MHV/MHV_exe on a intel-opt named
>>> compute-1-16.local by jmousel Wed Oct 24 21:59:50 2012
>>> > [73]PETSC ERROR: [20]PETSC ERROR: Libraries linked from
>>> > [35]PETSC ERROR: Petsc Development HG revision:
>>> -0500
>>> > [20]PETSC ERROR: [73]PETSC ERROR: See docs/changes/index.html for
>>> recent updates.
>>> > [73]PETSC ERROR: [20]PETSC ERROR: [35]PETSC ERROR: Configure options
>>> --download-blacs=1 --download-cmake=1 --download-hypre=1 --download-metis=1
>>> --download-ml=1 --download-parmetis=1 --download-scalapack=1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121025/bc0a0c81/attachment.html>
