[petsc-dev] corrupted ta->count with GAMG
John Mousel john.mousel at gmail.com
Thu Oct 25 09:43:38 CDT 2012
Jed,
That had occurred to me too. Unfortunately, my sys admins insist on using
OpenMPI due to some issues they have with getting SGE to properly clean up
processes with MVAPICH and MPICH2. Long story. Is there an option to get
back to the previous default behavior? I couldn't find the documentation
for -mat_bypass_jeds_more_efficient_algorithm_because_sysadmins_make_me.
John
On Thu, Oct 25, 2012 at 9:33 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> It's an Open MPI bug. I'll write the work-around, but have deadlines first.
> https://bitbucket.org/petsc/petsc-dev/issue/9/implement-petscsf-without-one-sided
> On Thu, Oct 25, 2012 at 9:23 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> The problem is detected in MatTranspose and Jed was messing with this a
>> few weeks ago ...
>> On Oct 25, 2012, at 6:48 AM, John Mousel <john.mousel at gmail.com> wrote:
>> Mark,
>> Yes, this worked before pulling. I hadn't pulled on that machine in a few
>> weeks though.
>> John
>> On Thu, Oct 25, 2012 at 1:18 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>>> Did this work before the pull?
>>> Mark
>>> On Oct 24, 2012, at 8:04 PM, John Mousel <john.mousel at gmail.com> wrote:
>>> > I just pulled and I'm getting the error below when running with GAMG.
>>> > [20]PETSC ERROR: --------------------- Error Message
>>> > [20]PETSC ERROR: Corrupted Petsc object!
>>> > [20]PETSC ERROR: corrupted ta->count!
>>> > [20]PETSC ERROR:
>>> > [20]PETSC ERROR: Petsc Development HG revision:
>>> 2b3cccd7bd8ff536f48616e4402b164ba9cd12d0  HG Date: Wed Oct 24 21:15:30 2012
>>> -0500
>>> > [20]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> > [73]PETSC ERROR: [20]PETSC ERROR: --------------------- Error Message
>>> > See docs/faq.html for hints about trouble shooting.
>>> > [73]PETSC ERROR: [20]PETSC ERROR: See docs/index.html for manual pages.
>>> > [20]PETSC ERROR: [73]PETSC ERROR:
>>> > [253]PETSC ERROR: --------------------- Error Message
>>> > [253]PETSC ERROR: Corrupted Petsc object!
>>> > [253]PETSC ERROR: corrupted ta->count!
>>> > [253]PETSC ERROR:
>>> > [253]PETSC ERROR: Petsc Development HG revision:
>>> -0500
>>> > [253]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> > [253]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> > [253]PETSC ERROR: See docs/index.html for manual pages.
>>> > [253]PETSC ERROR:
>>> > [253]PETSC ERROR: /nfsscratch/Users/jmousel/MHV/MHV_exe on a intel-opt
>>> named compute-6-165.local by jmousel Wed Oct 24 21:59:50 2012
>>> > [253]PETSC ERROR: Libraries linked from
>>> /Users/jmousel/SOFT/petsc-dev/intel-opt/lib
>>> > [253]PETSC ERROR: Configure run at Wed Oct 24 21:41:09 2012
>>> > [253]PETSC ERROR: Configure options --download-blacs=1
>>> --download-cmake=1 --download-hypre=1 --download-metis=1 --download-ml=1
>>> --download-parmetis=1 --download-scalapack=1
>>> --with-blas-lapack-dir=/opt/intel/mkl/10.2.5.035/lib/em64t--with-debugging=0 --with-mpi-dir=/opt/openmpi/1.4.3/intel COPTFLAGS=-O2
>>> FOPTFLAGS=-O2 PETSC_ARCH=intel-opt
>>> > [253]PETSC ERROR:
>>> > [253]PETSC ERROR: PetscTableAddExpand() line 145 in
>>> src/sys/utils/ctable.c
>>> > [253]PETSC ERROR: PetscTableAdd() line 75 in
>>> src/sys/sf//Users/jmousel/SOFT/petsc-dev/include/petscctable.h
>>> > [253]PETSC ERROR: PetscSFSetGraph() line 327 in src/sys/sf/sf.c
>>> > [253]PETSC ERROR: PetscSFSetGraphLayout() line 595 in
>>> src/vec/vec/impls/mpi/pmap.c
>>> > [253]PETSC ERROR: MatTranspose_MPIAIJ() line 2130 in
>>> src/mat/impls/aij/mpi/mpiaij.c
>>> > [253]PETSC ERROR: MatTranspose() line 4350 in
>>> src/mat/interface/matrix.c
>>> > [253]PETSC ERROR: PCGAMGFilterGraph() line 136 in
>>> src/ksp/pc/impls/gamg/tools.c
>>> > [253]PETSC ERROR: PCGAMGgraph_AGG() line 979 in
>>> src/ksp/pc/impls/gamg/agg.c
>>> > [253]PETSC ERROR: PCSetUp_GAMG() line 685 in
>>> src/ksp/pc/impls/gamg/gamg.c
>>> > [253]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
>>> > [253]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
>>> > [253]PETSC ERROR: KSPSolve() line 402 in src/ksp/ksp/interface/itfunc.c
>>> > /nfsscratch/Users/jmousel/MHV/MHV_exe on a intel-opt named
>>> compute-1-16.local by jmousel Wed Oct 24 21:59:50 2012
>>> > [73]PETSC ERROR: [20]PETSC ERROR: Libraries linked from
>>> > [35]PETSC ERROR: Petsc Development HG revision:
>>> -0500
>>> > [20]PETSC ERROR: [73]PETSC ERROR: See docs/changes/index.html for
>>> recent updates.
>>> > [73]PETSC ERROR: [20]PETSC ERROR: [35]PETSC ERROR: Configure options
>>> --download-blacs=1 --download-cmake=1 --download-hypre=1 --download-metis=1
>>> --download-ml=1 --download-parmetis=1 --download-scalapack=1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121025/ab5f9e2a/attachment.html>
