[petsc-dev] htmlmapfile error when building the manual
Karl Rupp
rupp at mcs.anl.gov
Wed Oct 17 11:06:27 CDT 2012
have you tried setting LOC to PETSC_DIR, i.e.
$> make alldoc LOC=${PETSC_DIR}
Best regards,
Karli
On 10/17/2012 09:59 AM, Milad Fatenejad wrote:
> Hello:
> My name is Milad Fatenejad, I am working with PETSc as part of the
> Plasma Surface Interaction (PSI) SciDAC project. I was encouraged to
> begin by using PETSc from the mercurial repository. I have cloned the
> repository and everything has been working fine. However, I have been
> unable to build the latex documentation and was hoping to get some help.
> So far, I entered the src/docs/tex/manual and tried "make manual.pdf
> LOC=/tmp" and got an error about not being able to open the htmlmap-file
> (see below). Am I doing something wrong? Does the LOC option have to be
> set to some specific location?
> Thanks for your help!
> Milad
> >>> make manual.pdf LOC=/tmp
> make[1]: Entering directory
> `/home/milad/petsc/petsc-dev/src/docs/tex/manual'
> make[1]: Leaving directory `/home/milad/petsc/petsc-dev/src/docs/tex/manual'
> Traceback (most recent call last):
> File "../../../../bin/maint/mapnameslatex.py", line 204, in <module>
> raise RuntimeError('Unable to open htmlmap-file: '+htmlmapfile+'\n')
> RuntimeError: Unable to open htmlmap-file: /tmp/docs/manualpages/htmlmap
> make: [manual.pdf] Error 1 (ignored)
> /usr/bin/pdflatex -halt-on-error manual1 > /dev/null 2>&1
> bibtex manual1 > /dev/null 2>&1
> make: [manual.pdf] Error 2 (ignored)
> makeindex manual1 > /dev/null 2>&1
> /bin/mv part2tmp.tex tmp
> grep -v "end{theindex}" tmp > part2tmp.tex
> make: *** [manual.pdf] Error 1
