[petsc-dev] misleading that ROSW uses SNES
Mon Oct 15 23:32:14 CDT 2012
On Mon, Oct 15, 2012 at 11:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    It is seriously misleading that TSType rosw uses SNES as the solver
> since it is only using SNESKSP and the algorithm really is built around
> only linear solves.  Are you sure that using SNES is the right model for
> this family of algorithms? Convince me.
1. Consistency in where the callbacks and matrices are stored.
2. Consistency in configuration of Krylov methods and preconditioners.
3. Lack of order-dependence when configuring the above.
4. Ability to TSSetType() part way through a run without needing to
reconfigure all of the above.
5. It's sometimes useful for debugging to run the Rosenbrocks with a true
nonlinear solve.
6. Ability to debug Jacobian correctness using SNES infrastructure.
7. No need to duplicate -snes_fd_coloring support outside of SNES.
>    I realize one person among us thinks we should use SNES for both linear
> and nonlinear solves, but he is wrong :-)
>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121015/58d2464f/attachment.html>
