[petsc-dev] Configure on Windows
Satish Balay
balay at mcs.anl.gov
Thu Oct 11 10:55:50 CDT 2012
you can specify zlib with the LIBS option to configure
LIBS=/cygdrive/c/dev/PFlotran/HDF5/lib/libzlib.lib
Satish
On Thu, 11 Oct 2012, Luis Manuel de Vries wrote:
> Hi,
> When running the following in Cygwin on Windows with the latest PETSC-dev
> code:
> $PETSC_DIR/config/configure.py --with-cc='win32fe cl' --with-fc='win32fe
> ifort' --with-cxx='win32fe cl' --with-clanguage=c \
> --with-mpi-dir=/cygdrive/C/Progra~2/MPICH2
> --with-blas-lapack-dir=/cygdrive/c/Progra~2/Intel/Compos~1/mkl/lib/ia32 \
> --CFLAGS=-D_CRT_SECURE_NO_DEPRECATE --ignore-cygwin-link --with-valgrind=0
> --with-c2html=0 --download-sowing=1 \
> --with-hdf5=1 --with-hdf5-include=\[/cygdrive/c/dev/PFlotran/HDF5/include,\
> /cygdrive/c/dev/PFlotran/HDF5/include/fortran\] \
> --with-hdf5-lib=\[/cygdrive/c/dev/PFlotran/HDF5/lib/hdf5.lib,\
> /cygdrive/c/dev/PFlotran/HDF5/lib/hdf5_fortran.lib,\
> /cygdrive/c/dev/PFlotran/HDF5/lib/libzlib.lib,\
> /cygdrive/c/dev/PFlotran/HDF5/lib/libszip.lib\] \
> --with-debugging=0 --with-petsc-arch=cygwin_hdf189_rel_24559
> I get the following error:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Compression library [libz.a or equivalent] not found
> I downloaded the HDF5 library from:
> http://www.hdfgroup.org/ftp/HDF5/current/bin/windows/HDF5189-win32-vs10-static.zip
> I tried renaming libzlib.lib to zlib.lib, but that did not help. Also tried
> copying it to the petsc-dev dir, that also failed.
> How can I pass the path to the zip library correctly?
> A few months ago I did not have problems running configure on windows....
> Any suggestions?
> Thanks,
