[petsc-dev] Unification approach for OpenMP/Threads/OpenCL/CUDA: Part 1: Memory
Karl Rupp
rupp at mcs.anl.gov
Sun Oct 7 09:34:53 CDT 2012
> Problem already solved http://dl.acm.org/citation.cfm?id=2145863 :-)
Oh, yes, these are the SnuCL guys, cf.
http://aces.snu.ac.kr/~jlee/Jaejin_Lees_Home/Pact11_tutorial.html
Their approach is to collect all devices across the cluster and make it
available as if it were all local on the same machine, cf.
http://www.acrc.a-star.edu.sg/astaratipreg_2012/Proceedings/Presentation%20-%20Jaejin%20Lee.pdf,
Slide 6.
As they are presenting results for the standard matrix-matrix
multiplication benchmark, memory transfer is not the bottleneck.
However, I doubt that the same works well with BLAS level 1 and 2
operations.
By the way, I've attached benchmark results for a simple BLAS 1 kernel
using double precision on an NVIDIA GPU using OpenCL (CUDA is
qualitatively the same, yet may have slightly lower latency). You
usually won't see this kind of benchmark result in publications on GPUs,
as they are considering BLAS 3 only, or hide this unpleasant fact in
diagrams starting at higher data sizes. For vector sizes below about 50k
(!!), one can clearly see that one is in the kernel launch overhead
regime, even if data transfer to the GPU is ignored. We are taking about
latencies of 10us here, which is in the range of 1us when running the
same benchmark on the CPU (I have to rerun benchmarks on latest SDKs,
maybe the situation has improved). For this reason, I suggest to refrain
from unconditionally submitting all types of jobs to an OpenCL scheduler
and rather preserve the option of starting a small job right away using
e.g. threadcomm (with the cost of an indirect function call, as Jed noted).
Best regards,
Karli
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121007/1844c25f/attachment.png>
