[petsc-dev] 1D heat equation decay and implicit TS results
Chetan Jhurani
chetan.jhurani at gmail.com
Mon Oct 1 16:06:16 CDT 2012
I'm using petsc-dev to solve the 1D heat equation
u_t = u_xx in [-1,1]
with zero boundary conditions and u_initial = sin(pi x).
The exact solution decays to 0. The exact
log10(norm_inf(u)) is a linear function of t.
I use the standard 1D hat basis functions on a uniform
mesh to discretize. The mass matrix remains tri-diagonal.
When using TS with TSTHETA (or TSBEULER) and exact linear
solves (PCLU), the FEM log10(norm_inf(u)) follows the exact
curve for around 4500 time steps and then gradually,
over a few hundred time-steps, changes slope.
See attached figure. x axis is step number. The code is
attached too.
The results were obtained using
-ksp_type preonly -pc_type lu -ksp_atol 1e-200 -ksp_rtol 1e-200
The 1e-200 tolerances were added just to be way below the
norm scales in the problem above.
Questions:
Is it a bug in my code or is there another good explanation?
Do I need to turn on some tolerance related option to see
the exact convergence behavior for more time steps?
Chetan
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121001/e934fa26/attachment.ksh>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121001/e934fa26/attachment.png>
